Top plungers "pop" into the t-20 with video
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Top plungers "pop" into the t-20 with video
    Aug 2010
    Wetumpka, AL
    93
    Quote Originally Posted by Uncle Vin View Post
    I agree. the transmission is not adjusted correctly. In fact, I hope your plungers are not going in too far, If they are, you could tear an o-ring. Re-read the adjustment section of the online re-build manual. On a side note, it would be very helpful if someone posted a video on how to properly adjust the T-20. It took a long time for me to figure it out. Uncle Vin
    I don't disagree. I am sure I need to go through the adjustment process again. Once I get the wheels back on then I will re-tweak the plungers. It seems the bottom plungers are moving in/out without any problems it is just the top ones that "pop" due to the strange angle. But I don't think the top plungers are going to far in to cut the o-rings but I will double check. Is the "clutch tool" that RR sells worth the moola?
    Dec 2009
    Long Island, New York
    99
    Quote Originally Posted by arp35 View Post
    He sells two different tools. The "clutch tool" is used to get a secondary (driven) clutch off the transmission. It works well. The other tools are the plunger adjustment tools. They work well also. He just recently posted intructions on his website on how to use the adjustment tools. It's worth a read. I obviously purchased both of the tools. No complaints. Uncle Vin
    And yes, I believe that the plunger adjustment tools are worth the $25 it costs to buy them. Uncle Vin
    Last edited by Mike; 10-04-2010 at 05:14 PM. Reason: merged two consecutive posts. You can edit a post if you forget something ;)
