congrats on the new to you Attex. that machine should be an ABS tub. abs repair is super easy. first get some donor plastic. i can send you a little if you need it. get a quart paint can with lid, a cheap paint brush, and a quart of acetone from any hardware store. get some bondo spreaders from an auto parts store. cut the donor plastic into small pieces and throw them into the paint can. dump in some acetone and put the lid on. stir it once a day for a few days to make "ABS GOOP" if it seems too thick add acetone, to thin add more donor plastic. you are shooting for something between peanut butter and ketchup. once your goop is ready, cut the crack out into a V shape with a dremmel, or die grinder. go an inch or so past the visible part of the crack with the V. take a cheap paint brush and brush some acetone on the crack area. go back over it with acetone every 8-10 min for 3 cycles. then use an old spoon to scoop some goop onto a bondo spreader and work it into the crack. let it dry for a few days then repeat the process till the crack is filled (always waiting a few days between layers). the most important part: DO NOT do anything that will flex the body for a few weeks after the repair is made. the abs goop takes WEEKS to dry fully and if you drive the machine, or move the body around a lot you will crack it again before it ever has a chance to set up. don't even worry about cleaning the bondo spreader after use. once the abs goop dries it will chip right off the spreader and you can throw it back in the can of goop for reuse. also, i have found that a working temp of close to 70 degrees and very humid seem to work the best. i'll wait to do abs repair on a rainy day with all the shop doors open
