Hello everyone!
Just wondering if someone could help me out.
I bought an 80's (I think) Argo 6x6 a few months ago, which had the engine replaced with a 16 hp Briggs Vanguard four years ago. When I bought it, we had to pull start it, but other than that it ran fine.
I replaced the battery & it would start and run great while I moved it around the yard to work on the body.
I then installed a cheap (free, actually) winch & took it for its maiden voyage (same day). I got it stuck & was happy I had the winch, but it started stalling at idle right after that episode. I don't have a great deal of experience with motors, but I want to learn & I would rather not take the Argo to the shop.
Can anyone suggest where I should start looking for a solution?
It starts great, but unless I give it gas, it will eventually stall, regardless of the choke setting. Ditto even after it's warmed up.
Should I be looking into adjusting the carb? Could it have anything to do with the winch installation? Maybe I fouled the plugs with all the puttering around before that maiden voyage?
Any help would be appreciated.
