Axle Bearings
Results 1 to 5 of 5
Thread: Axle Bearings
    Nov 2010
    Red Lion, Pa
    52
    Axle Bearings
    Any reason these won't work on a 1st gen ? 8 Bearing 6205-2RS 25x52x15 Sealed:Ball Bearings:VXB
    thanks,
    scot
    Jan 2008
    Vicksburg, Michigan
    3,507
    Depends on the flange style. Maybe this will help you.
    http://www.6x6world.com/forums/attex...-bearings.html
    Nov 2010
    Red Lion, Pa
    52
    Larry, thanks
    I have the more common non-rounded style bearings. I almost got 1 axle apart tonight, i was able to get the most outer part of the axle off (the part with the wheel drive flange on the end). then was able to press the bearing out of the aluminum housing, after removing the snap ring. So know I have a solid axle thas has the bearing still on and some sort of collar that the seal seals against. Does the collar come off also ? Looks like the solid axle might be bent ? Can the seal collar be purchased ?
    thanks,
    scot
    Nov 2010
    Red Lion, Pa
    52
    Also, is there any reason that I can't make new drive flange axles with the newer bolt pattern on, instead of bolting a adapter to my old axles ?
    thanks again,
    scot
    Jan 2008
    Vicksburg, Michigan
    3,507
    The collar comes off. Make sure you press the bearing towards the collar because the axle is 25.4mm one side and 25mm on the other side.
    For the seals, you can take the old seals in to napa and they can measure them up and order replacements. It may not hurt to bring the bearing and the axle in to so they could measure that. If your lucky they may be able to just go buy the numbers on the seal if there is any. I took one in once and I think it was near 10 bucks a piece.
    For the hubs you can make them. Member Birddog1148 made some and showed what he did. His posting is here, post #87-88 shows the details if you dont want to read through the whole thing.
    http://www.6x6world.com/forums/attex...-st300d-3.html
