What did I buy ?
Results 1 to 10 of 14
Thread: What did I buy ?
    Nov 2010
    Red Lion, Pa
    52
    What did I buy ?
    Well jost got back from purchasing 2 attex'x from a guy on craigs list. One in what seems like very good shape and a not so good parts ? one.
    1st is the nice one, it has a t-20 trans and a chaparral g50b engine. Runs, moves, needs throttle cable
    The second is a 400 chief (superchief ?) has a body band, roll bar, and a jlo twin and a t-20 trans.
    any idea on what the first is and year ?
    thanks,
    scot
    statesville, north carolina
    2,604
    the first is a superchief. (you can find the serial # for both in the circled are in the attached pic... first 2 #'s indicate the year... you may need to sand the frame/ paint/ rust/ grease to see the #). i can tell you that machine #1 is not a '76.
    where are you located?
    Nov 2010
    Red Lion, Pa
    52
    ok, looks like it is a 1977 supercheif, the other I will have to get later. I live in Red Lion, PA
    thanks,
    scot
    That first one is a 1977 or newer Superchief, which was one of the fastest AATVs that Attex made. The other one which you said is a Chief, would have an ABS body, a JLO 400, a different grille that is black with ridges molded in it, and a stripe going down the side of the body.......also the T-20 will have a disc brake on each side of it.
    Nov 2010
    Red Lion, Pa
    52
    OK, just got back from picking up the 400 cheif , and here she is. A little work is needed..
    scot
    Oct 2008
    N V.A.
    83
    looks like the roll-bar is on backwards
    "Ooo, neckties.....contracts.....HIGH VOLTAGE!!"
    2,604
    the chief needs some TLC, but I've seen a lot worse.
    The body looks really nice on the Chief. Just clean all the dirt and grime off it, and a little bit at a time, get a clean rag and dip some acetone on it and wipe the body. The oxidation will instantly disappear! Then take some fine 500 grit sandpaper and wet sand it.......jump up to some 1000 git and wet sand it once more. Then wax it and that thing will shine better than new!
    Nov 2010
    Red Lion, Pa
    52
    Quote Originally Posted by Air Bud View Post
    Yes it is, not bolted down......
    scot
    May 2008
    Putnam, NY
    1,074
    Just curious what the green attex body is. Previous project? Body came with these machines?? Inquiring minds want to know
    Attex Super Chief - Sold.
