Had a chance to work on the cuyuna a bit today, one set of points is stuck open, will clean them up & work on it some more tomorrow. CDI sounds interesting...has anyone put one in yet?
xenoah cylinders pic in parts ,mamual kinda remind me of a hirth twin 400 440 493
but i know that the x engine was made in japan or atleast tied to fuji that helped in the development of the engines for chap and rupp , prob very simmilar to the 488 polaris engine too..
i bet it uses a electric starter from either a kawasaki/ccw or a polaris that is f theya renot all the same as the kawi and the ccw /jdx8 engines use the same electric starter
We're using two of them now and working on a third one. The hardest part of the job is finding the CDI units. Cuyuna only used CDI at the very end of their production from what I can find out, but they also produced a liquid-cooled 440 for use in PWCs. The liquid-cooled engines had CDI ignition and at least some of them were interchangeable with the fan-cooled models.
This stator looks like it may be for a CDI setup.
NEW 440 JLO Stator - eBay (item 200372516741 end time Feb-02-11 07:21:00 PST)
Good find, George. That's for a CDI all right, and looks like a Cuyuna, but marked JLO ( I don't think JLO ever produced an engine with CDI). It's awfully pricey to find out later it won't fit. One thing I forgot to mention is that the point ignition stator plate and CDI plate are installed 90 degrees differently. If you can't find a fan housing that was made for CDI, you'll need to drill and tap your housing for the new stator.
The Cuyuna is running...runs like a top! Now I am on a mission to find an electric starter & matching ring gear. Seems easier & cheaper than CDI.
that looks like its the ebayer .
anny way i de glued my cdi box .
i found my glasses and looking at the cdi box the colder joints are terrible in spots one wire that no doubt is needed is not connected to the board
so if you have a tin can stylce cd box like eraly kawi , suzuki arctic cat or cuyuna you can deglue them with a hot gll;ue gun to attemtp to repair them electronically
i have a bad cdi box for a 78 panther wich is almost the same as the cuyuna same manufacuter nipendenso
that is going on the hot glue gun tratment after i get done here
you actually may try a suzuki engine for and arctc cat and see if you can find a flywheel stator combo
my hunch thier is opne out there ...
when i get enough junk sled engnes
thanxz
440 Cuyuna is still in sled. Runs good till it gets warm,then quits. Let it sit for 10 min. it will start and run for another 10 min. Changed stator and timed it,problem persists.Need Help!!!!! Thanks for any ideas. (Plenty of gas and blue spark,then none or yellow)
