Kold Kutter ice cleats on supertracks
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Kold Kutter ice cleats on supertracks
    Oct 2008
    Thornton, CO
    646
    I am going to need to replace the functionality I had with something. NCT, pics would be great. I am looking at the factory cleat and it turns out that there are two versions. "Old style" which looks like it has one biting edge and two bolts and a style that looks like a chunk of channel with two ice edges and one bolt. The old style can be had for considerably cheaper. Anyone have experience with both styles?
    I can't tell from the pics of the old style whether they clear the plastic in the tracks??? A pic would be cool.
    Quote Originally Posted by JohnF View Post
    John the picture such as it is(Iam a bad photog)I have posted to my gallery as Iam so computer unsavy I still cant post to a thread no matter what I do,so those cleats and studs have been in those tracks for years and the cleats themselves are wore badly they did stick up further when new and are held in by one bolt.N.C.T
    Oct 2008
    Thornton, CO
    646
    Hey thanks! Here's the thumbnail:
    They look pretty good for wore badly.
    Anybody with a comment about the "old style" cleats? I can get a set for $40 on sale right now.
    Northern BC
    2,990
    Quote Originally Posted by Obsessed View Post
    Hi John,
    Great to meet you both and Dan also. Had a blast playing in the snow with you guys. Im on our way home now, but when I get back to my desk ill post some pictures from our ride on the other thread.
    Just read your post about breaking the studs out of your tracks, so it got me thinking about mine. We were climbing and spinning on some really rocky slopes and that probably where damage could have occurred. here is a picture of how I installed the 5/8" gold diggers in my tracks.
    When I get back in the shop im interested to inspect for damage and see if I lost a few also.
    Thanks for taking the time to come up and hang out with us. Really enjoyed the time with you guys.
    Tim
    Hi Tim
    Couple questions on this pic you posted:
    All the long bolts are are in one row, and all the short are in a row. Do you think there would be an advantage to staggering those bolts........every second bolt would be long in both rows?
    The way the extension plates are "layered", it looks like the extensions could be bolted together the other way, which would put a leading edge on top to bite into the snow. The way it looks in the pic, there is more of a slight ramp laying into the snow.
    I could be wrong here, but it looks like the current configuration would have better traction in reverse than forward. Am I making any sence here? Looks like the pic is taken from the back of the machine.
    Oh ya, your email inbox is full
    Nov 2010
    Adair, Iowa, USA
    471
    Hi Tim
    Hi RD...just got home and getting ready to unpack, but wanted to share some thoughts with you...
    i think if you look closer at the picture of the 21" wide track you will see the rear snow flap and the name plate above it (let me know if i might be miss understanding your question)...the picture is taken from the front...your thoughts are excellent and identical to mine regarding the direction of the layered track extentions...i did in fact install the tracks in the direction you are suggesting, because that was my first thoughts also...now i am not so sure...the benifit of having them mounted that way is obvious, but it tends to lean the bolts (studs) backwards for less traction in forward (but possibly more stopping power on ice....I actually ment to install the tracks on the opposite side, for more lift (im guessing) in the snow and also a better attack angle of the stud on icy slopes (my more recent theory)...im not really convinced which direction would actually give the most traction on power snow as the flexable outside edge of the track has a bit of a "cheese grater" affect in either direction...i attempted to test forward and backward traction a little bit, but weight distribution is so different from front to back, im not convinced the results were trustworthy...perhaps a better test would be to lay an unmounted track out in the snow or on ice and try to drag it from either end...next trip out i plan to take a couple more pieces of tracks assembled in different ways and try the new "drag test"...honestly its really hard for me to take the time or focus on testing once i start playing, im not even good at taking any video (i wish David or Dan was out there riding with us...lol)...i really enjoy the pictures and videos afterwards to do a lot of my observations and research....i also took quite a bit of time studying the different styles of tracks that were on several of the newer snowcats out there and i am certain of several changes that probably need to be made to "up" snow performance a little bit...like John, i was also super impressed with Dan's 24" wide tracks and how well they were able to climb steep snow :-) not sure if that was from the extra width or the extra "bite" from the larger paddles...probably a bit of both, but either way Dan's machine is pretty awsome in the snow and really had the look of a high dollar snowcat
    as for the bolt pattern...my first thought was to install the longer traction bolts closer to center for two reasons...first, i think that it is a more stable part of the track due to the flexability of the outer edge (by design) and probably gets more downward pressure from the tire...second, i wanted to be certain to have the traction closer to the center where it would be less likely to "snag" a hazard and possibly damage the outer edge of the track or try to roll a track off....I do think that you are correct and that a staggered pattern would improve "bite"...after seeing how easy the machine was still able to turn in all the different situations, im not so sure that you wouldnt be better off putting long bolts in all the holes...
    im not sure if the gold digger ice screws or the bolts helped the most, but after the other guys left, we did help pull a snowmobile trailer out of the ditch and back up on an icy road, and i was very impressed with the traction we had on glare ice... seemed like a pretty good blend of traction and the ability to still skid steer
    sorry about the email...will try to get back to work tomorrow and also get some pictures uploaded :-)
    tim
  6. #16
    Nov 2010
    Adair, Iowa, USA
    471
    Hi Tim
    hey RD...here is a better angle to see the direction of the overlapping track sections...tim
  7. #17
    Northern BC
    2,990
    Thanks Tim, You answered my questions. I thought the pic was taken from the Back of the machine.
    Looks really good, by the way.
    Nov 2010
    Adair, Iowa, USA
    471
    Quote Originally Posted by LarryW View Post
    Hey Tim,
    Just curious what are the bolts for extensions? Do the threads get damaged, or I mean Im assuming they do. Are they threaded rod or what do you do to take them off? Cool track though!
    Hi Larry,
    Just got a chance to inspect the screw in studs and bolts after putting 26 miles on it this past week in WY and while riding with Dan and John. Here is what i have found.
    The ice screws are starting to show some wear (but super inexpensive at only $9 for the whole set of 120) from spinning on rocks and pavement and i should probably start to look for a little higher quality carbide tiped version to replace them with whenever its needed. The bolts actually look really good and they only show damage on the very tip that is always riding on the ground. (They were also pretty inexpensive grade 2, 5/16" x 2" carriage bolts from the local hardware store)
    Didnt break or show any signs of bending any of the bolts or gold digger ice screw (except for the one bolt that i lost on the trail the morning that we all started riding together)...even the threads look pretty good considering all the rocks and stumps we were driving on.
    Here are a few pictures and some close up shots.
    Tim
  9. #19
    Jan 2008
    Vicksburg, Michigan
    3,507
    They seem to hold up quit well actually. If you ever do need to remove the nuts from the bolts looks like you could cut the bolts off easily with a cut off wheel just on top of the nut. Probably wont hurt the tracks with the cutting heat up there. Thanks for the updated pictures. Sounds like you've had a blast!
