Hey guys,
Not sure if this is the right place for tech talk, but i am having a problem with my winch on my MAXII..
I used it once to pull off a snow bank, it would go both directions when i used the switch.. The winch seemed to be straining to pull the MAX (i was standing next to it hitting the switch not in it).. Then the winch stopped reeling cable in & going forward..
Reverse worked though, so i let it reverse all the way to unspool it, then as you know when it gets to the end, the cable begins to spool from the opposite direction & the spool now starts to reel in line.. Sooo now all the cable is reeled back in but there is not reverse so i cant unspool!..
Is this a problem in the winch or switch possibly, that there is only one direction?
