Clutches for Kohler Command 25
Results 11 to 20 of 30
Thread: Clutches for Kohler Command 25
    Sep 2009
    Bryan, Texas
    748
    They're probably just the same, I think that the CH730 is just an updated version of the CH25. I'm gonna take a wild guess and say that the one I'm buying is a CH25. I'll ask the guy and know for sure tomorrow. I looked at the one on ebay again and it says it came out of a vertical shaft engine, I wonder if that'll make a difference.....
    2010 Chevy Silverado 1500
    1974 Honda ATC 70
    1986 Honda ATC 250ES Big Red
    There is no Z in Diesel!!
    Sep 2009
    Bryan, Texas
    748
    Well it is a CH25, but the crank on ebay is for a vertical CH25, so it won't fit. The good news it that the owner of the local small engine shop knows a place that will turn down the crank it has now, and re-heat treat it for me. So now we're back to what clutch(s) to get for it. I also want a new trans clutch since I will be getting a new one for the engine. So, R.I. or should I look for a better deal elsewhere?
    1974 Honda ATC 70
    Stonewall... i have a 25 Kohler Command in my Sierra Trail Bossand I found a 1 1/8 straight shaft roller clutch on cartpartsplus.com.. Its rated up to a 100HP and so far its worked like a champ. Its got a slightly larger diameter so the top end increased a little too. the part number is cpp09.
    Sep 2009
    Bryan, Texas
    748
    That looks like a nice clutch, how much time do you have on it, and what driven did you use?
    1974 Honda ATC 70
  5. #15
    Sep 2009
    Bryan, Texas
    748
    Ok, I need to get my project rolling (no pun intended) again, so I really need to find out about what clutchs to get. I am currently watching a 1 1/8" x 3" crank on ebay, but in case that doesn't work out I talked to the machine shop that my small engine guy uses, and they said that they can turn the PTO down from 1 7/16 to 1 1/8 for $60-70 no problem, they've done it plenty of times. Now I just need a set of clutches!
    I don't like the idea of buying the R.I. clutchs that costs more than I paid for the engine, but if it comes down to being the only option, I will. I like the clutch that rdebaeke mentioned, but would like to hear your opinions on it, and what driven you suggest using with it. 1 1/8 inch straight shaft clutch
    If you have any other suggestions I would love to hear them.
    1974 Honda ATC 70
  6. #16
    Sep 2009
    Bryan, Texas
    748
    Anybody?
    1974 Honda ATC 70
  7. #17
    I'm in the same predicament that you are Stonewall. I have a big block 31HP Briggs Vanguard that's going in my Hustler BIGFOOT and the shaft is too long to fit in the 1 1/8" Comet Duster clutch that I have.
    The bore in the clutch only goes about 2" in unfortunately so I don't know what my other options would be......cut the shaft down? Get a different clutch?
  8. #18
    Sep 2009
    Bryan, Texas
    748
    I think that cutting the shaft to the length you need would be the best option. Take it out of the engine and to a machine shop, and they should be able to cut it to the proper length, then drill and tap for a new bolt.
    Have you used that clutch on anything before? If so, how does it perform?
    1974 Honda ATC 70
  9. #19
    Quote Originally Posted by Stonewall View Post
    I never have, but I heard that they're decent. They don't have rollers in them, just weights that fit in the slots of the clutch, so I guess there's less to go wrong with them since there are fewer moving parts.
  10. #20
    Sep 2009
    Bryan, Texas
    748
    That sounds like it would be better, I may try one of those. What driven are you using?
    1974 Honda ATC 70
