Hi Guys (and girls?) new member in the UK here.
I have a 6x6 Amphicat, believed 1973, been stood maybe 15 years. Sometimes outside, sometimes inside.
CCW Engine. Made by Kyoritsu - Nori for Curtiss-Wright
single cylinder 2 stroke.
Model KEC 225
Electric start (which works) & pull start.
Reading this thread, it does not seem a popular engine. Used more often snow mobiles perhaps?
Got the flywheel, off unbelievably easily.
Removed dirty points & cleaned. Refitted, gapped by eye. Gap shouldn't be critical to get A spark so long as they open & close?
Magnets inside of flywheel quite clean, but gave a quick rub over with some light emery paper.
Original HT lead has been cut about 3-4" out from the casing then goes into a screw connector with a replacement length of HT lead. I've removed the jointer, cut both ends & rejointed. The replacement length has some chafe damage but is not through & lies well away from anything metal.
Tried a different plug - direct to earth by means of a battery jump lead.
After having cleaned the points I really expected to be in business. NOTHING. Not a sign of a spark.
The back plate & coil pack looks like this one:
Welcome to Richard's Relics Parts for ATV's
There is what appears to be an electronic ignition device bolted to one of the engine mounting rails. A small black plastic box.
There are 3 wires coming out of one end which connect with push-in connectors to wires going into the engine & so to the coil area.
I have split & cleaned all 3 joints.
There is a 4th (yellow from memory) wire comes from the engine, which is not in use.
On the diagram on top of the box, it shows the 3 wires out plus one in at the other end.
There is no sign of there being, nor having been, a wire there.
Your ideas very welcome.
