Not sure if anyone had seen this. Showed up on Craigslist when I searched for 6x6. Looks like it may be made from plywood? I sure would like to know what they are using for a transmission.
Mike
Mike
Last edited by Mike; 05-10-2011 at 10:15 PM. Reason: link removed, see my post (#9) as to why
I seem to remember seeing a thread about this thing. I believe the guy who built it is a member. If I rember correctly, it is made of plywood, and it uses a Dixon zero turn lawnmower transmission.
2010 Chevy Silverado 1500
1974 Honda ATC 70
1986 Honda ATC 250ES Big Red
There is no Z in Diesel!!
I believe you are correct. He used a vertical shaft engine and some sort of lawnmower tranny. And a good portion of the build was marine grade plywood. I'll find the thread and post a link if i
http://www.6x6world.com/forums/other...-finished.html. Here it is!
Last edited by amphibious drew; 05-08-2011 at 07:47 PM. Reason: Messing with larryw/then lost the link and had to put it back in. Thats what i get for having a little fun.
I saw it too and I ordered the manual. Looks alot better than the 'EDGE' plans I ordered a couple years ago. I'm going to start building this weekend. Will keep everyone posted.
I bet you did since you are the person also selling the plans.
Why do people insist on being crooked? This thread was already promoting his plans fine without his input but that wasn't good enough so he has to sign up with a different user name to build some buzz around his product. Now he and both of his usernames, goodyeartravis and smyser are permanently banned from this site.
cj-ate, I removed the link in your original post after he signed up with another username and lied about buying his own plans. If he will stoop that low then I don't want anyone on the site to actually purchase his plans. I just wanted to let you know so you didn't wonder where the link went. And just to clarify, it is definitely nothing against you. I know you were just sharing those plans with everyone here.
