Originally Posted by
MIteyMT
That rubber does not quite look like it's a half inch thick, and I can see it has nylon strands?
What about a belly that looked liked the header of a draper swather. Imagine the vehicle belly, halved laterally, with each half having an axle driven conveyor belt, gear reduced to match ground speed, so that your entire belly is a drive surface. Ground clearance would be reduced, traction surface and weight increased, swimming surfaces increased dramatically. There would have to be a barrier between the top and bottom to prevent binding when you drive over high spots. I would think it would be cool for snow and water, but perhaps troublesome for dry land.
