What you are describing is the Staun beadlock system, great system, very high rent. The smallest size currently in production will fit 9 in. rims,8-10 wide.
Yes Grease thats the one
Greasemonkey's link shows the tube bigger in diameter than I recalled. Lets assume that setup is on our machine. Put a tire on it at 1 or 2 psi, etc. Then go hit the trails. Diving like a Senior, you'd have the normal great low psi ride like you have with k rims/matt's wheels. Then go hit the logs and ruts hard. What happens? Your tire flexes till it hits the tube and then stiffens up. Dual stage air presure!
They have quite a few good idea's!
Jeff
02 Argo Bigfoot
