16hp vanguard with tapered threaded end shaft from generator. Will a clutch go on it
Results 1 to 8 of 8
Thread: 16hp vanguard with tapered threaded end shaft from generator. Will a clutch go on it
    Aug 2011
    Scranton Pa.
    81
    I'd like to know if anyone ever used a 16hp vanguard that came from a generator that has a tappered shaft with the threaded end on it. If i bought the motor i want to make sure i can get a clutch to fit it so i can convert to a 4 stroke from 2. Thanks JasonK
    Apr 2011
    Ohio
    149
    In my experience It will Not work you have to replace the shaft or the clutch will not go on far enough I have a 5 hp off a log spliter I wanted to use for a go cart that would not work.
    Aug 2011
    Scranton Pa.
    81
    So basicly i'd have to replace the whole crank shaft in the motor? The old 2 stroke 400 in there now has a tappered shaft a 30mm like all older snowmobiles had. I figured there was a 3 smaller diameter clutch that might fit & be held on with the bolt through the middle. The shaft looks pretty long I'll post some pics of the motor.
    Aug 2011
    Scranton Pa.
    81
    [IMG]vanguard[/IMG]
    Aug 2011
    Scranton Pa.
    81
    Here's pics vanguard 16 tappered shaft. Can i put a clutch on this for argo use
    2 vangard.jpgvanguard.jpg I had to start a new thread sorry. This was from a generator & has a tappered shaft with threads on the inside end of it. The ? is can i get a clutch to fit this?
    Last edited by Mike; 10-06-2011 at 12:05 PM. Reason: moved this thread to the existing thread. No need for two on the same topic
    Jun 2008
    cape girardeau, mo
    273
    I personally have not seen one...by all means that does not mean that they do not make one....but my thoughts, is there enough meat on the shaft to have it machined to fit a 1.0" clutcth, or can you just purchase an adapter sleeve for the clutch. one of our members here placed a link to an adapter for just such an application..although at the time I was not in need for that situation, the info did not stick with me...
    May 2008
    Ontario,Canada
    489
    Yes!! walk in to your local John Deere dealership they have clutches in stock that bolt right on,,,,,JD AMT's JD Gator 4x2 and JD gator 6x4 all use the common tapered shaft
    "Argo 8x8's only" type of guy
    "old school Argo expert"
    Aug 2011
    Scranton Pa.
    81
    Thank all of you's for the replies. Someone's selling this motor & wants an offer made. I wanted to be certain it would work for me in my argo before i made an offer.
Tags for this Thread
