it runs
it runs
The correct way to fill the trans is to Remove top plug and bottom plug, its on back/rear of trans, down low..its a bugger to get to also...once bottom plug is removed, pour fluid into top plug untill it runs out of bottom plug, then your done..install plugs and enjoy! lol
as for fluid, everyone on here runs something different i think..lol i bought the best most expensive fluid i could fine. (it should hold 1 qt total. thats from being totally empty, to completely full. The guys boast about the "GM Sure Trak" fluid i think its called. Might be Ultra Trak also..lol im sorry, bad mind today. anyhow, do a search on here and you'll find what kinda im talking about.
Something else to look at is, How far out do the plungers come? when you pull the stick or push the stick, how far out do the little plungers on the tranny come out? It may have band issues?
The T20 takes Automatic Transmission Fluid. The brand Wagz said is fine, but you don't have to worry about breaking the bank on fluid. Most T20s don't see high-heat applications, and are always under zero pressure. If your transmission isn't running any fluid at all right now, it would be a good idea to add a quart, run the machine around for a little while, drain, and refill. Draining the T20 (i.e., getting that quart that resides below the bottom plug) can be a difficult process, but if you raise the front of the machine up (winch or come-along to a garage rafter, tree limb, etc.) and drain it out of the back of the transmission that way, it'll be easier than pulling the transmission itself. The fluid will drain into the tub, but you can try to catch it in a plastic bag if you can shoe-horn one in there.
Add an ounce or so of limited slip differential additive (available at just about any auto supply store) to reduce/eliminate band chatter, should it develop. Right now, it seems that your transmission is a bit twitchy, so after adding fluid let us know if it acts any differently for you....
