Check and see if you solenoid is gettin power when you push the starter button. use a test light if possible, or use a volt meter if needed. My neighbors does same thing sometimes. Check your fuses. If yout gettin the 12v down to the solenoid, but no crank..i'd say your solenoid is El'Junko!
if not 12v down to it, check your button and wiring and connections.
