2010 Chevy Silverado 1500
1974 Honda ATC 70
1986 Honda ATC 250ES Big Red
There is no Z in Diesel!!
The store being removed didn't have anything to do with it since it was a separate piece of software. Try this: Look to the right of the URL address bar on your Internet Explorer. Is there a broken page icon? If so, try clicking on it and see if it will let you view the site in a compatibility mode.
I have been trying to reproduce the error on my end and I can't. If I could, I would be more help. Sorry it is taking a lot of back and forth to get anywhere.
The compatibility mode button is there, but when I click on it, or anything else in the browser window (any of my favorites on the favorites bar, the "home" button, or any of the tools, menu options, etc.) while it's on the main page, it crashes and reloads the main page. So it sticks in this infinite loop, and every time I click on something it goes around again, either until I close the tab or IE decides it's tired of trying to reload it and gives up showing an error page.
I will try to figure out how to take a "screenshot" to show you what I'm getting.
1974 Honda ATC 70
Try it now and see if it makes a difference. If not, continue reading: If you start off on a page other than the home page, does it have the same problem? For instance, start by going directly to this thread instead of going to 6x6world.com homepage
Well now it's working on IE, but the blue bars with the post number and date are gone from the tops of the posts... Is that what was causing the problem?
Edit: also, all the commas are gone from the "currently active users" list.
1974 Honda ATC 70
The time-date stamp is a different (known) issue with IE9. Let's ignore it for now and, if you don't mind, try it one more time in IE. I think I know what is causing the issue but I want to test it one more time.
Well, it seems to still be working properly right now.
1974 Honda ATC 70
I remembered that I had tried some code that was a little more ipad friendly for videos about two weeks ago. I modified it again tonight and it seems to be working fine now. Thanks for bringing that up and helping me work through it. By the way, since you have an ipad in front of you, can you see the video on the home page of the site at all on your ipad? That was one of my other projects that I haven't had much luck with. Thanks.
No video pic on home page, just a white box on the ipad.
Not even a white box on iPhone, just black like the rest of the background. The red squiggly under misspelled words is gone now too...
1974 Honda ATC 70
