Originally Posted by
North Country Tough
Sometimes can be a real problem,starting fluid works no question,that is except for me coordination is crucial and timing is everything,and it takes 6 weeks to grow back eyebrows,if you know anybody with a tire shop or a trucking company you can use their Blast tank,I built one years ago basically a air pig with a 11/4 or 11/2 outlet on goes a ball valve and a 12 inch defuser and pump it up to 110 ish pounds stick the defuser into the bead area and clamp on a air chuck to the tire valve and open the ball valve and boom tire on bead.
Bead seaters also work very well for "Potatoe Launchers!!" :-D but yah...i'd soap up the beads and rims real good, and then Light that mother Up with some Starting Fluid!
