Home made rubber tracks
Page 3 of 10 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 94
Thread: Home made rubber tracks
  1. #21
    What is the width of the tires? At 24" you must have done some tub modifications? Thanks for the track guide template!
  2. #22
    Jun 2009
    Montreal, Canada
    471
    10" for the tire width and yes I had to push back up the low part just behind the front seat. Easy to do and hard to spot for most people.
  3. #23
    Nov 2011
    az
    24
    Thanks for the dimensions, and again a really great job
  4. #24
    Sep 2009
    Beaufort, Sc
    264
    Any chance you have tried to swim with them yet? I wonder how they would compare to the adair tracks?
    HUSTLER 980 NOS BUILD
    HUSTLER 980 TRAIL MACHINE
    HUSTLER 950 PARTS MACHINE [
  5. #25
    Jun 2009
    Montreal, Canada
    471
    the track profile got a lot of paddles but I'm not sure it will swim a lot. It's a winter track set optimized for ice and snow. Right now there's no open waters to test any swimming abilities; next time to test it in water will be in April/May.
    So if your goal is to get a set of swimming tracks, better get the Adair system. (even more if you are in SC)
  6. #26
    Nov 2009
    Sugar Grove, IL
    117
    What would you recommend is the best way to cut a rubber track?
  7. #27
    That's really cool SMOG. Very nice.
    Jun 2009
    Montreal, Canada
    471
    Quote Originally Posted by sparkola View Post
    may not be the best but I used this :
    http://en.wikipedia.org/wiki/File:Reciprocating_Saw.JPG
  9. #29
    Nov 2009
    Sugar Grove, IL
    117
    LOL The Sawsall!!!! Love it. I have been pondering just taking a snomobile track like yours and cutting a double paddle section and fastening to my Supertrackes like every other track segment. I think I could end up with similar traction results as you did. I think the Supertracks are a good base(mounting) to attach rubber track sections to. They don't weigh that much and I would reduce the weight of the rubber by only using half. A plastic track segment has to weigh half of what an even sized piece of rubber track does so the overall result would prolly weigh less than a fully rubber track, no?
  10. #30
    Smog,
    I noticed you offset the track so the extra non tire contact area is toward the inside of the tub rather than on the outside. Was there a practicle reason for doing it that way? I was thinking I would want it the other way to get more spacing between the track and tub. What am I missing?
