Duromax Throttle Return
Results 1 to 5 of 5
Thread: Duromax Throttle Return
    Apr 2011
    Yelm, WA
    82
    ok got a duromax 4 stroke engine, still lookin for a clutch does anyone know and have some pics on how to set up a trhottle on these? the factory one is not really spring loaded so do i need to fab a high tension spring to get it to work right?
    Aug 2011
    Oakland, IA
    48
    Have you had any response? don't see any here , I have the same question hope someone has the answer.
    Jan 2008
    Vicksburg, Michigan
    3,507
    Hey guys,
    I have a PowerMax which is now called DuroMax. I had a few different spring set ups that always seem to stiff. It has to be strong enough to pull it back which makes it hard to give it any throttle. I finally came up with a good solution. I unhooked all the original throttle stuff and threw it in the weeds. Trash works too. I did leave the connecting linkage from the governor arm to the carb. butterfly linkage connected. Then I hooked the cable to that linkage. I ended up connecting it better then in the picture by drilling 2 little hole in a bolt for the rod and cable. And now the governor itself pulls the cable back. No spring pressure to fight with your fingers. It was the best mod I ever did. When its not running there is no return though but that's not an issue.. But when its running it works good and is very effortless to hit the throttle. And runs so much stronger. I thought it would just rev more but its better all the way around. I think the original design doesn't let it open up all the way. So it not only gained some MPH by revving more but accelerated quicker and was easier to pull. You will have to be careful with over revving but I have revved the crap out of it with no problems. So you have to be careful but not really, lol. Here is a picture.
    Aug 2011
    Oakland, IA
    48
    Great help Larry Thanks!!
    Apr 2011
    Yelm, WA
    82
    Larry you are the man
