Gear drive track system
Results 1 to 10 of 14
Thread: Gear drive track system
    Jan 2010
    Reno NV,
    61
    Has anyone tried a gear drive track system like a tank or dozer? I could think of a design or two but wasnt sure if someone has done it.
    Road? What road? I blaze my own trail!!!
    Buffalo, NY area
    2,968
    ....like replacing the wheels and tires with cogs that drive a track? To date, I don't know if anyone has but I've had mental pictures of just such a setup bouncing around in my head for years. It wouldn't be that hard, but the amphibious quality might be hurt a bit with the cogged-driven (e.g., Bobcat) tracks that are out there.
    Give us your ideas...
    Dec 2011
    Peoria Heights,IL
    223
    If someone tried that, id sure like to see a picture! thatd be cool! I still like the track set up my dad had on his max when I was a kid, theres a picture of one in the gallery somewhere. had the tubes on either end of the tub to support the tracks, but that thing was said to be unstoppable since the tracks extended forward of the tub so much
    Quote Originally Posted by MikeyM View Post
    I think you're refering to the very first track system that Recreatives put out on the Max II. There was a Max II with that track system that popped up for sale a time or two in New Jersey on Ebay. I think A 6X6World member ended up getting it.
    Jan 2010
    Reno NV,
    61
    Exactly! Would require a bit of fab to ensure stability and perhaps a few doner snowmobiles.
    Sep 2009
    Bryan, Texas
    748
    I thought about this type of setup as well. It would require some type of undercarrage for lower bogie sets if you wanted decent ground clearance. Suspension could also be incorporated into a track system like this.
    2010 Chevy Silverado 1500
    1974 Honda ATC 70
    1986 Honda ATC 250ES Big Red
    There is no Z in Diesel!!
    Buffalo, NY area
    2,968
    Quote Originally Posted by Stonewall View Post
    At that point, you're basically throwing a Cushman Trackster's tracks underneath an amphib. The mental image gives me goosebumps. Why couldn't you just take the entire bogie suspension out of two old sleds and put them under each side of an AATV? On something like a four chain attex machine, you could use the front axle as a rigid mount for the suspension and drive the track system with the center and rear wheel on each side. You could also incorporate part of the suspension mount into the area where the bearing flanges bolt to the frame. Something along the lines of an extension of the Max IV bearing extensions that they currently use for the track setup.
    Sep 2009
    Bryan, Texas
    748
    I knew I rembered seeing something like this a while back:
    http://www.6x6world.com/forums/autom...trackster.html
    1974 Honda ATC 70
    Oct 2008
    Thornton, CO
    646
    Using a snowcat as a model, I think you could get a system like this done pretty easy. You need the snowcat style tracks that have cogs that fit a sprocket on the front or rear axle and use a track tuner type device to turn all the other axles into bogie wheels.
    Jun 2009
    Montreal, Canada
    471
    you can get waterjet cut HDPE with the required "sprocket teeth" and you can built the tracks with baler belts and angle iron/aluminium
    Round Baler Belts
