@001 MAX IV with Rubber tracks
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: @001 MAX IV with Rubber tracks
    Oct 2011
    Canadian Border in Massena, New York
    143
    Angry @001 MAX IV with Rubber tracks
    WHY WHY WHY WHY?!!??!!
    My max with factory rubber tracks and track kit w/5'' extenders.Solid axels with support channel connecting all 3 wheels. Tracks have cut an immense groove through the rear of tub on both sides !!! All axel bearings are good no movement in axels at all There is at least 3 1/2'' between tub and track. The only thing comes to mind is when torquing a hard turn the the tires give on the side walls enough to bring the track to close to tub All tires are at 4 1/2 #'s of air and holding on rim just fine. If this is the way it is going to be......anyone want a Max??? Only riding I have been doing is a little plowing around the yard !
    Next question .......can the tub be welded back together and how?
    Meadville, Pa
    3,286
    Sorry to hear about your troubles. I can't say what happened but it can be welded using a plastic welder Nd some abs welding rod. It sucks to have to fix it but at least its fixable.
    Oct 2011
    143
    Quote Originally Posted by amphibious drew View Post
    Any suggestion on where to buy one Drew? Thanks and yah this sucks. wish I knew why so I can stop it from doing it again after I fix tub
    Aug 2007
    saskatchewan
    378
    hi sorry about your problem could you post some pics of your set up and the damage it may be helpful to help you diagnose the problem
    Mar 2011
    Colonial Heights, VA
    497
    http://www.6x6world.com/gallery/memb...f-a-patch.htmli did my using a heat gun, an old plastic fender, and a rivet gun. I have a few pictures of repairs i did on my tub.
    Mar 2010
    Oconee County, SC
    823
    I got my plastic welder off Ebay. Urethane Supply Co Model 5600HT Mini-Weld Model 6 Airless Plastic Welder (0694687001445) | eBay They are easy to use, just make sure you have the correct welding rod, HDPE. The kit comes with only a LDPE rod. HDPE welding rod can be gotten from US Plastics Corp 1/8" HDPE Oval Welding Rod | U.S. Plastic Corp. One pound of welding rod will last a long time. Just make sure that the unit is turned off before plugging and unplugging it or it will burn out.
    Buffalo, NY area
    2,968
    Hey Hogneck,
    Some pictures of the damage to your machine would go a long way to determine the proper way to fix it. Since your Max IV tub is polyethylene, a good start would be to get some scrap HDPE from one source or another, and try to weld the holes/cracks back together with some thing welding rod you make out of the scraps. Let's see the damage first, before we get too far.
    We can save it.... I promise.
    Oct 2011
    143
    How do I drop pictures onto a thread?
    Oct 2011
    143
    [IMG][/IMG]
    [IMG][/IMG]
    THE CUT IS ALL THE WAY THROUGH TUB ON LEFT AND RIGHT SIDE
    [IMG][/IMG]
    THERE SEAMS TO BE ENOUGH ROOM TO RUN TRACKS.
    Last edited by Mike; 01-26-2012 at 10:54 PM. Reason: merged three consecutive posts. You can post as many photos as you want in one post.
    Buffalo, NY area
    2,968
    Man, that's tough....
    The only thing I can surmise, is that you're getting a lot (a LOT) of flex out of the side walls on your tires, and that's letting the tracks slide over toward, and grind into the tub when you're either turning, or when one side of each track is on an incline. I've seen something similar on Adair tracks when one side of the track is tweaked over toward the tub. I don't think it rubbed the tub, but it came darn close.
    What tires are you running, and at what psi? Outside of repairing at this point, let's figure out how to alleviate the problem. Is a couple-more psi an option, in order to stiffen up the sidewalls? I think that welding up the tub with some home-grown poly rod is an option. If you struggle to find any black poly, I have a butt-load of black poly from an old black Max IV tub I can mail you.
Tags for this Thread
