carburetor help on a fd620
Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 60
Thread: carburetor help on a fd620
    Feb 2009
    buffalo,ny
    61
    Hey guys I am having trouble getting my carb dialed in it seems to be running rich and it stalls out sometimes when I'm plowing snow or rev the motor up high I just had new seals and float needle put in also had it cleaned very well,I also have fresh gas in and new plugs .When I rev up the motor in nuetral and hold it steady at one spot it sounds like its hitting a rev limiter and chugging does anyone know what adjustments I could start with and is the adjustment that has the black plastic on it the idle adjustment?
    Thanks ,Nick
    99 Argo Conquest.....ERIE icefishing machine
    Oct 2008
    Thornton, CO
    646
    What is your elevation and did you happen to notice the main jet when you cleaned it?
    The plastic capped screw is an air screw to adjust the mixture for the low idle circuit. You adjust your low idle RPM via a screw stop at the throttle linkage.
    Oh yeah, did it run fine before the carb work and now it doesn't?
    I've seen them surge when lean. For me it means I need the next larger jet (I change elevations a lot) but it can run lean if there is an air leak, like the manifold gasket is broken.
    It can also surge when rich. This you could probably smell but it will also smoke a bit and cough soot. This could be fuel leakage in the carb; although in this carb I don't know where, unless the float valve doesn't work. Could also be a stuck/broken choke.
    Another edit
    It also happened to me when I think my fuel pump was going out. I think it probably surges when the engine fuel consumption exceeds the pump capacity.
    Feb 2009
    buffalo,ny
    61
    Yes the exhaust is coughing soot the choke seems ok cuz when I pull it out it will kill the motor I had the carb rebuilt and cleaned professionally and it did run great before I had the work done but I was getting gas in my fuel before that's y I had it looked at there is really nobody around here that services argo so I'm doin it myself
    Feb 2009
    buffalo,ny
    61
    And I did mess with the linkage screw and the black plastic screw so maybe I got them setup wrong I hope!
    Oct 2008
    Thornton, CO
    646
    Quote Originally Posted by SixGunNick View Post
    We'll assume rich then.
    That tells us it closes, we need to peek in there and make sure it is opening all the way.
    ... but I was getting gas in my fuel before
    gas in the oil, maybe??? There's a thread on here talking about that. That doesn't seem like a carburetor issue though.
    No problem...
    So let's start working through this...
    Don't go thinking I'm an expert - I'm just a guy that has his carburetor apart a bunch of time. So, with the caveat of "This is what I would do"...
    I don't have a black plastic cap. I think it is to limit the screw travel. If it comes off I would take it off for this. Carefully screw it in until it seats - not tight, you can break things - just until you can tell that it seats. Then back it out 1 3/4 turns. Maybe 2. A little rich here is our goal.
    Now, if it already idles high (RPM) I would leave that adjustment alone but I want it to run at idle somewhere around 900-1000 RPM so I may give it a twist to higher RPM.
    Start it. Adjust the idle RPM down until you think it is a little higher than where you want it. I dunno, 900 RPM. You're probably just using your ear right now, that's okay and having the idle a little high helps to hear the changes, too high and you aren't in the idle circuit anymore. Let it run so that we do the rest when it is warmed up.
    Be aware of hoody string, loose long sleeves, hair, any long stuff that can get caught in moving parts. Don't have them. You are going to futz around the engine while it running. You'll be close to the fan. Had an uncle help me once that forgot that and stuck his thumb into the fan - RRRAAAAAPPPP - scared him but the fan is spinning the direction that just scares ya and doesn't cut off the thumb.
    Now very slowly turn the air screw in. We should have had the engine running lean so you should hear the RPM increase and smooth out and then eventually drop. You are searching for the point where the RPM peaks and the engine runs the smoothest so you might have to go in and out a bit. Make small changes (1/8 - 1/4 turn) and wait a bit for it to stabilize. Once you find that point - BAM, you're set. I guess put the cap back on.
    Now adjust the RPM down to where you want it. Mine is about 780 (I have a tachometer) but this needs to be low enough that you can shift without too much grinding. Sometimes the lights blink a bit at idle.
    That's your idle circuit. There are pilot jets involved in this but as far as I know they aren't ever changed. I suppose you could play around here but I change elevation probably more than most here and, doing the above, it idles just fine.
    Let's see what that does for you. But if we need to go further...
    The other adjustments you have are float level and main jet. Float level will affect how the engine acts when you go from idle to WOT - it is sort of a part of the accelerator pump function, and the main jet affects mixture of the main fuel delivery circuit.
    I would like to know which jet you have and the elevation where you are running. The jet has a number stamped on it. It is behind the anti-afterfire solenoid - the only thing with an electrical wire. You should be able to see this without taking the carb apart, well, except for taking the solenoid off.
    To remove the carb - unplug the fuel pump - start the engine - and let it run until it starves. (just to empty as much of the fuel as we can)
    Two wing screws takes the cleaner and filter apart. 7 screws removes the top plate - there is also a breather tube at the back that pushes into a tube underneath, remember that when putting it back together. 2 12mm nuts hold the carb on. The anti-afterfire solenoid has a connector at the far end if it's lead (I hate that!) - it just presses in and pulls out. The throttle and choke linkage are wires (one will probably have a spring over it) on the left side. With you left middle and index finger hold the linkage up into the holes on the control arms - you want the linkage to go up and come out of these holes when you lift the carb out and not fall into and go further onto the control arms. Lift the carb out - jiggle and wiggle so that solenoid clears stuff. Go straight up so that you don't spill what little fuel is still in there on everything. If there was a spring on the throttle linkage then you'll stop at some point after the linkage wire frees to get the spring out with needle node pliers. After I get the carb out I usually go into the street (I have one) and turn the carb upside down to dump out what little fuel is left inside.
    Now take the solenoid off (don't loose the copper gasket), grab a flashlight (and for me something to magnify ) and see if you can read the number on the jet.
    Assembly will be the opposite - when we get there.
    Feb 2009
    buffalo,ny
    61
    Hey john thanks for all your help I think my carb is somewhat dialed in it does not seem to be running rich now starts up fine,idles great but when I throttle up it still has rev limiter effect happening as I can see it revs up then a shot a fuel shoot in from the top of the carb and the linkage starts bouncing,and then does it over and over again.I had seen on another post where it was said that maybe it could be the linkage springs are worn out and its letting it bounce like that,my fuel pump seems good and fuel filter is working properly
    Dec 2011
    Ontario Canada
    672
    If your float needle is not adjusted to close when the bowl is full it will run rich and when the engine is not running gravity can fill the crank with fuel. A fuel shutoff will solve that but the engine will still run rich. Check the float level and set it a bit lower so you know it's shutting off.
    Oct 2008
    Thornton, CO
    646
    Cool.
    There can be many reasons for the surging. Right now I wouldn't look at it being the governor or a linkage problem. (It could be, but that would be later for me.)
    I've had this happen to me twice. Once when too lean. I had the high altitude jet but was at a much lower elevation. This same thing will happen if there is a bit of something reducing the effective size of your jet. Say a little varnish or a bit of old rubber hose. This surge was immediate when I went WOT and was rhythmic. (sine wave)
    The other time it surged sporadically, actually ran ok at first. I did everything. Clean carb, swap jet, ... nothing was fixing it. I thought my pump was fine because fuel came out the hose alright. I finally decided to just change out the filter/pump/hose. Mostly because there was nothing else left. Fixed it. In fact, I haven't had a carburetor problem since. The new pump is a low pressure pump like the one on the machine but the flow is much better.
    Above describes how to get to the jet. It might also come clean with seafoam in the fuel. I've fixed quite a few seasonal varnished up engines this way.
    We could do a pretty easy check of the pump in a couple of ways. You could measure it's flow with a graduated jar and a stopwatch. You could disconnect the pump so it doesn't run - cut the bottom off of a soda bottle and configure it to gravity feed the carb and test if the surging goes away.
    I would get at the jet first. It's pretty easy and after you've done it a few times you'll be in in about 2 minutes flat. Grab a spray can of carb cleaner and go to town on the jet. Your elevation is pretty low so your jet should probably be the 112. At least if Buffalo is where you ride.
    In Edit: Also if the gasket to the manifold is leaking then the engine will run lean. It shouldn't be - it's a thick simple gasket - but if it's not there...
    Oct 2008
    Thornton, CO
    646
    Quote Originally Posted by Bazoo guy View Post
    Gravity draining fuel into engine:
    I don't think that's really true with this carb. At least not on level ground. The fuel/air mixture has to travel over the top of the bowl vent level in all circuits. Maybe if the cover gasket is bad. (SizGunNick - we may need to check that!)
    Running rich due improper float adjustment:
    The main jet is in between such that the fuel level can have no effect on main circuit operation but the fuel level is an important adjustment for the accelerator pump function. These engines are very testy on this by the way.
    Feb 2009
    buffalo,ny
    61
    ok i called an argo dealer/service shop and he also almost immediatly said that it sounds like a fuel pump problem so i will try to test that tomorrow when i get home from work is that silver thing screwed into the fuel pump the fuel filter or is that part of the pump,if that is the fuel filter i guess that could be the problem because i had changed a second filter that is located up by the carb(sorry i am not mechanically inclined)i will try to set up a gravity feed to the carb and see if it runs good if not i will pull the jet out and also make sure the man gasket is good i know its there cuz i pulled the carb to take it in due to the fuel in oil problem i explained in an earlier post which was sort of resolved with a temporary fix there was believe it or not a hole in the carb right above the throttle shaft in the aluminum in a corner and that was allowing fuel drain down into the motor i used gas tank sealer(like jb weld)to seal the spot and havent had a problem since
    Thanks again for your help guys i really appreciate the replies
