I am stuck again with a perplexing issue. In one of the rear axels below the output for the T-20 spocket is an idler spocket for chain adjustment which is now a new one.Below that is the driven double sprocket with a single hub on solid spline axel. It will not stay in alignment with Idler and T-20.It is riding inward and popping of course .I take it this is why the bearing in Idler crapped out the first time. I can move it back to home with a big pry bar and 2lb hammer. even after set screw is out I still have to hit hard to drive it over. This wil be the third attempt to keep it where is is supposed to be.I am very tempted to bugger a spot weld on her this time for I am about done with the disappointments. My question is....... If all sprockets and chains are in alignment,..what is causing the hub to travel on shaft ? Stupid little 1/4-20 allen set screw won't hold crap. Should be a 5/16'' or larger .
