so I bout 2 coils to replace mine,lost spark on the right lung. Can anybody tell me the correct wiring for the coils?!?!?
thanks once again guys
Last edited by Mike; 02-07-2012 at 10:31 PM. Reason: moved thread to correct forum
Pg 16,17 & 18
Depends what ignition system you have.
http://www.asberry.net/files/TwoStrokeSM.pdf
Hello,
Coils most always have two terminals. The one marked positive (+) goes to 12 volts and the negative (-) goes to your ignition side like your points or module.
Good luck.
This engine has a magneto primary and 2 secondary coils.
The wiring is different if it has manual or electric start and the type of keyswitch or if the lights have a separate switch.
The manual describes the different types of systems.
