I got a wild wolf that has flats. Current size is 21x11x8.
From what i've seen they start at $60 each.
Are tubes an option?
Where is a good site to buy tires?
Thx Drew
Thx Drew
First off, don't buy from Route 6x6/ Richard's Relics or you'll go broke. Your best bet is to do a search here on the site. You'll want to use a 21x11x8 or 22x11x8 tire, preferably without tubes, but if you just want to get the machine up and going, you could always run tubes for the time being. Take a look at this thread:
http://www.6x6world.com/forums/tire-...razy-high.html
Here's some useful info for you. For adapter plate templates (if you have the 3 bold balloon tires) use these, if you don't have them, don't worry about it.
http://www.6x6world.com/forums/conte...e-adapter.html
And here's a GREAT deal on rims if you need them. Get the 8x7 in either 4 lug, or 5 lug, depending on what you need.
8 Inch Trailer Wheels | RecStuff.com
As far as tires go, check Craigslist, ebay, and post an ad here on the site. Hope this helps, and welcome aboard.
Looks like i will do tubes for now. I saw some on ebay that will cost less than $100 for 6.
My 4 wheeler currently only has 2 tires on it due to rear diff being shot and i need to fix it first.
Its been a real pain due to the CV joints frozen stiff in the diff.
Thx drew
Hey Drew....
The problem with running tubes in these tires is that the tubes (just about always) eventually slip within the tire, since we operate the tires at such low psi. At 2-5 psi (or so...) the tube isn't held tire against the tire hard enough to stop it from slipping. Once the tube begins to slip, it will shear off the valve stem at the rim. It's almost guaranteed to happen unless you inflate the tube to 20 or 30 psi, which is way too high an operating pressure for the tire....
