Originally Posted by
spookum
Go for it buddy! Just make sure to use schedual 80 pipe. I would only worry about it shattering if it impacted a pointy rock. what would keep a guy from filling it full of cheap expanding insuative foam to add compression to the inside of the pipe? it would also keep them from becoming filled with mud, water or snow and i think that a case (another forty bucks from wall mart) would go a long way. it will also increase your floating capacity
I had a similar thought to filling it, but would suggest a self leveling driveway filler manufactured by sika. its like rubber in a tube. More expensive that foam but adds rigidity where foam doesn't. Also it is a misconception that filling something with foam adds boyance. A hollow hogs capped at both ends will weigh more filled with foam than filled with air hence reducing boyance. Want it does do is prevent water, a much heavier material, from filling the space if a hole is present.
