my tires are turning on the rims pinching the tubes i am running 3 psi what are some thoughts
thinking of putting 5 psi or putting screws in the rims
thats as far as i thought
forgot its a 8 wheel conquest 22 10 8 run a sucks
I wouldn't recommend the screws as it can break the belting in the tire bead destroying the tire. A better option is to clean the rim and paint it. Then use the silicone or bead sealer that people reccomend to help "glue" the tires to the rims. No tubes needed. If you have leaks throw in some slime and you'll be good to go
