295 jlo lost spark
Results 1 to 5 of 5
Thread: 295 jlo lost spark
    Apr 2012
    vershire vt
    38
    295 jlo lost spark
    i got a jlo that seems to have spark then looses it then comes back. anyone know what it might be loose wire points not adjusted right. its in a mckee roughrider
    Dec 2011
    Ontario Canada
    672
    Quote Originally Posted by fishnvt78 View Post
    loose flywheel or poor ground on the coil or faulty kill switch.
    check the wires on the keyswitch also.
    Mar 2009
    Alabama the Beautiful
    888
    I had a honda oddesey do the same thing and it ended up being the pulse coil.
    Butler, PA
    191
    It is either the points, a loose wire or the plug wire, try burnishing the points and see if that helps if it does order a new set because they are probably about shot.
    Apr 2012
    vershire vt
    38
    will give it a try thanks
