I didn't think anyone is arguing against you. I agree, if you only run lower speeds it won't be as much of a problem.
The red light is because you choose to be invisible on the board. It has nothing to do with what you posted. If you hover over it, it will tell you what it is.
As for the speeds, there are stock machines that do go that fast. That's what everyone is trying to say.
As for the heat gun, if you look in the gallery, I know of two members that have used that to make tires fit. Tory G has done that to get 25" tires on his Max II
Also, there are several other members that are running the 24" frontier tires that have had to heat their tubs to get them to fit.
Just something to keep in mind when heating your body. The Attex ST/295 is ABS plastic. The people that heat their bodies for extra clearance have poly body machines. I'm not 100% sure what the heat would do to the ABS plastic, but from what I have seen on old Attexes, around the muffler exit (where there would be more heat), the plastic tends to be more brittle. Also, I don't know how much the ABS plastic body would bend when you heat it up, I don't think it is as pliable as the poly bodies either. Just something to consider.
Good point. I've learned that ABS doesn't react that well to heating while trying to repair cracks. I think you could bend it if you were careful and just softened it up a little and had a curved mold to evenly push against the plastic.
I think so, probably around 30 ish.
I don,t think a High Lifter , Outlaw tire , will fit either an Argo or even a Max IV , that will take taller tires , and surely not an Attex . The Out law tires are REALLY WIDE !! Dan has a Max IV , with 26" Vampires on it , and these tires rub the lower tub at 2 psi , when he turns . He has to run 5/16 spacers behind each wheel , to be able to run the low psi on Vampires . But , at 2 psi , the Vampires soft side walls give the best ride out of all the tires Dan has used on his Max IV he told me . This includes the factory Terra tires and the Swamp Fox Plus tires . Dan also told me he is going to heat the top of the lower tub , over the tires , to gain some more clearance , so he can run the Vampires at 2 psi . Dan said at 2 psi , the traction is awesome , when driving through the swamp reeds , over any tire he,s tried so far on his Max IV .
