Sound off with your Max type, Serial #, and Year
Page 5 of 43 FirstFirst ... 3 4 5 6 7 15 ... LastLast
Results 41 to 50 of 421
Thread: Sound off with your Max type, Serial #, and Year
  1. #41
    Mar 2011
    Colonial Heights, VA
    497
    I have been told that the newer Max II's have different inside diameter on the inner bearing. Also they should have the snap rings to hold your sprokets into place instead of the set screws. Another up grade is the metal base throttle handle instead of the older all plastic throttle handle.
    Quote Originally Posted by carbidegrinder View Post
    I supposedly have a MaxII, 2004. But after all these posts I am wondering.... Serial # 19134. 16hp briggs vanguard and square headlights...What do all you guys think? oh and I have splined axels but inner and outer bearings are different inside diameters
  2. #42
    Mar 2012
    Brooklyn, WI
    885
    Talked with Jay at RI my Max is a 2002 Max IV with factory track option Serial # 18536. It was originally sold by Bob at BC Wheels in Wyocena WI.
    Keith.
  3. #43
    Nov 2009
    2,910
    IMG_0112.jpgIMG_0111.jpgI wanted to hijack this thread and add some info on old maxII tubs. I came across a maxII with the serial # in the 500's, I'm guessing that is early 70's. It still had the #40 chain on the axles. The lower tub has a very different looking backside. This is the second tub like this I've seen. I wonder if the cut outs were for a jet drive???
  4. #44
    Attachment 9398Attachment 9399I wanted to hijack this thread and add some info on old maxII tubs. I came across a maxII with the serial # in the 500's, I'm guessing that is early 70's. It still had the #40 chain on the axles. The lower tub has a very different looking backside. This is the second tub like this I've seen. I wonder if the cut outs were for a jet drive???
    Jim, those were provisions for dual propellers. I think jpswift1 posted some photos. I'll see if I can find them.
    Edit: Here is a thread from Jeff http://www.6x6world.com/forums/max-a...ropellers.html but I thought there were photos somewhere that actually showed the propellers.
  5. #45
    Aug 2012
    Sandstone, MN
    31
    I just checked on my Max IV with RI ---when I purchased was told it is a 95 but RI informed me that it is a 93 with a serial number of 10161. Two years doesn't make a difference to me---I love it!
    jnrmoto
  6. #46
    The folks at Recreatives believe that there are technical drawings for the gear boxes that were driven off the two rear axles to power the dual rear propellers. I don't know if these were ever in production or not though. All of the tubs like that were ABS plastic before they went to HDPE.
  7. #47
    Oct 2012
    Powhatan, VA
    279
    2000 Max IV 900-T
    Serial #17165
    Solid splined axles
    25hp Kohler Command
    Borrowing tools is for the weak.
    2000 Max IV, 25hp Kohler Command, 26" Titan Tru Power AT's
    1996 Max IV, 18hp Briggs, 24" Serwas
    1998 Max IV (project in waiting)
    1995/1999 Max II, 16hp Briggs, 21" Rawhides
    Hustler 950 (Project in waiting)
  8. #48
    Mar 2011
    497
    1. Kunzmm137: 1973?? Max II Serial# 3095 converted to 4 stroke
    2. CBass: 2002 Max II Serial# 18564, 2004 Max IV Serial#:19274, and Max II Serial# of 17060 and is a 2000.
    3. Coosaridgerider: 1990 Max II Serial# 8985
    4. Monoped: 1999 Max II Serail# 157...
    5. Model Citizen: 2000 (SS Max II) Serial# (17059???)
    6. Thebuggyman1: 1990 Max II Serial#9344 and the BIGFOOT Serial# 17752
    7. Aetractor: 1999 Max II Serial#15646
    8. Drewstang: 1985 Max II Serial# 7462
    9. Blown84gt: 1994 Max IV Serial# 10410
    10. Maxoverdrive: 1988 Max IV Serial# 8036
    11. Akranger72: 1995 Max IV Serial# 11582
    12. Mad-max: 1983 Max II Serial# 7127
    13. M38inmaine: 1992 Max II Serial# 9668
    14. Outdoorsy74: 1998 Max II Serial#14177
    15. Iwantonetoo: 1992 Max II Serial# 9710
    16. Gambler: 2003 Max II Serial# 19002
    17. Carbidegrinder: 2004 Max II Serial# 19134
    18. Kghills: 2002 Max IV Serial# 18536
    19. Jnrmoto: 1993 Max IV Serial# 10161
    20. Xbunsenx: 2000 Max IV Serial# 17165
  9. #49
    Oct 2012
    Ohio
    38
    Called the nice people at Recreative today, they said my RIM 4 seater #10539 was made in December 1976. Did they call them Max's back then?
  10. #50
    They sure did. RIM, which was just the name for the early Max IV's. RIM stands for Recreation Industry Military, if I remember correctly. And they've always been called Max ever since Recreatives started in 1969.
