Ok Thanks
Ok Thanks
I forgot take pictures before I started but the whole top was covered with paint.
ATTACH=CONFIG]9284[/ATTACH]paint side.jpg
Sorry about the pics not loaded right. Ill reload them again soon along with my other running Chief that has the body band and winch.
Attachment 9287Attachment 9288Attachment 9289
It definitely takes some work but your upper is starting to look good again. Keep it up your efforts are already paying off.
Amazing work! It looks like that Chief has undergone quite the transformation. That looks ten times better in its original bright yellow color than any paint or bedliner. Plus this way, nothing will be chipping or flaking off. Like Drew said, it's a good bit of work, but it's really worth it. Keep it up and thanks for the updates.
These pictures are better. The paint is actually off the top now and I will get those pics soon. This is the other Chief that my Father helped me put together. Everything was in the green body. He is a retired Machinist and Fabricator and he made the body band for the 3000lb winch. We now want to make a rollbar. Does anyone know the measurements for the factory Chief rollbar and the size pipe used? Once the rollcage is built I will swap everything to the Yellow body. You were all right about not using Rino Liner and to remove the paint. It really looks good and my Father was also surprised how good it turned out.
