But if you do the geo motor with polairs clutches you can have a 4:1 and a .76:1 drive. And when 40 HP at 5000 RPM gets boaring, just buy a complete head (300)with stainless everything, jump the timing and have 100 HP???
Sorry that i have missed a few of these threads, been a little under the weather. Looking great Marc and can't wait to see it start taking shape and move into it's own as # 9(Copper Head). Happy Birthday (Yesterday) A Springer make for a Great Birthday gift!!!!!!!!
Has it arrived yet?
Looks like it will be another feat of engineering on your part, wish I had your ambition. That long travel should make for a smooth ride for you.
Have a picture of the blackbird before it was started you may want to look at before you sell it, may be your original?
Been a while since i posted on the Copperhead progress. one major hold up was i wanted to upgrade the front band brakes to something that actually worked. Whipper supplied discs but when I considered the factory calipers they would have been a challenge to fit and quite expensive for their mediocre performance. I finally settled on dual piston hydraulic kart brakes due to their compact size and mounting arrangement. They also fit under the stock floor and clear the chains easily. The master cylinder is also a kart unit and is actuated by the stock brake. The suspension is is now installed and aligned. The engine is a Performance V Twins Eagle 4 which will probably go in this weekend.
Acta non verba
Very nice.
Expensive?
Looking great!
Wow, that suspension looks sweet, and the brake set up looks trick as well. Keep the pictures coming!!!
