Kaw FD620D cylinder imbalance
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Kaw FD620D cylinder imbalance
    Nov 2009
    Sugar Grove, IL
    117
    Were compression tests done with both plugs removed? If the adjecent cylinder had the spark plug in, it will throw off the readings. If you had both plugs removed while testing the cylinders and only came up with @ a 2% difference in compression readings I wouldn't worry about it. Once you get more than 10% difference, it's time for a repair. Those are pretty good readings for a cold engine by the way.
    Oct 2008
    Thornton, CO
    646
    Yes, both plugs removed.
    I thought that was good cold. Thanks for the confirmation. It's my understanding that cold readings are sort of worst case? (I'm no compression reading expert)
    And the fuel pump was unplugged. But that's really a story later when I couldn't for the life of me get the thing started.
