Replace my trottle cable evey thing seemed ok but it broke agian in the handle.cable seem to be put in the right way.It broke off right at the small ball on the end in side the handle.I have a 1990 vangaurd with a briggs motor
never will ride anything with less then 6 wheels again
I am not sure if this is the issue, but with cars I have seen a rare issue where the engine is not grounded correctly and the throttle cable acts as a ground. What happens is the cable gets hot and breaks off at one of the ends.... Not sure if this is your issue, but it may be worth a try....
Was this a new or used cable?
This is actually a fairly common problem with Argo. The throttle assembly is an item that I have at least one back up in reserve. I do this because I took a 5 mile ride through the swamp when my first one broke, I had to improvise a throttle cable from bailing wire and a screw driver, got me back to the truck but I learned my lesson. I may rig up a thumb throttle instead of the twist unit at some point.
The Argo throttles are not well made anymore.
well I did replace the starter some time ago and the ground wire clam was not put back onto the side of the motor because I lost the screw but did find it show I will be putting that back on.Maybe I should go with the thumb throttle to seems to be better from what peopleare saying.Do you still use the same cable because I just got a new one yesterday
I actually had a spare made at an atv specialty shop, they used a higher quality ball unit in the twist throttle which seemed to do the trick. The cost was $30.
