Hi guys,
I've read all that I could on this forum re: tracks, drive chains, bearings, axles, chain tensioner systems, and chain wind-up. All the info has been very helpful indeed.
So here's the situation: I bought an 04 avenger last spring in great condition (only 83 hours). The machine came with 18 inch argo rubber tracks installed which I removed right away. I put the tracks back on a few weeks ago for the winter but a few things are not sitting right with me. I'm experiencing what I suspect is chain wind-up on the right side.
My axles and bearings are great all around. I have 25 inch rawhide III tires. My chains don't appear to be stretched as I have lots of room left on my tensioners. Essentially, my machine appears mechanically sound.
I followed the installation instructions perfectly (accounting for tire size, positioning, and psi). Took the machine out a few times in the snow and seemed to be pulling to the right. I hoisted the machine and checked out how the chains were performing and here's what I found:
On the left side: all seemed good. Chain was not too tight. I manually turned the track several rotations in all directions and the chain never got too tight.
On the right: all the chains were very tight with no play at all. Were I turned the tracks in reverse a few revolutions, they would become less tight on top. Then I manually turned the tracks forward a few revolutions and they would immediately get super tight......I mean very tight. Not having this issue on the left side. The tensioner slider blocks on the right are under lots of pressure.
I'm guessing this is why the machine is pulling to the right a little because of the added resistance. I really want to solve this problem to avoid premature wear and damage to the machine.
Any suggestions, ideas?
