Siezed Briggs 16hp Vanguard... buy new or rebuild?
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
Thread: Siezed Briggs 16hp Vanguard... buy new or rebuild?
  1. #21
    Apr 2011
    598
    I just pulled the old 16hp from my 6x6 and have to pull flywheel to change stator. In the process of doing something else I broke one ear off the flywheel...that is when I called it a night and put my hammer down gently and walked away. Good thing I have an extra flywheel...just have to get the patients to go back at it and try and get the old one off now....
    Still debating on if I should swap it out for the 16hpe duromax???????
    —Will Rogers
  2. #22
    Aug 2012
    Houston
    17
    Well pulled the flywheel and found the culprit.... a bolt... better than a blown motor but it did mess up the stator and flywheel magnets...
    if i'm going to replace the flywheel and stator should i replace the magneto's too?
  3. #23
    Dec 2012
    Wildwood Fl
    126
    it shouldnt have messed the coils up their mounted on the outside of the flywheel, they should be fine
  4. #24
    Aug 2012
    Houston
    17
    Any suggestions on where to get a flywheel and alternator (stator)?
  5. #25
    Nov 2009
    Michigan
    730
  6. #26
    Dec 2012
    Wildwood Fl
    126
    your local mower shop may have a used flywheel off a bad motor but i would get a new stator..
  7. #27
    Meadville, Pa
    3,286
    I think racerone3 said he has a flywheel. He is a good guy and trusted forum member. I would check with him
  8. #28
    statesville, north carolina
    2,604
    Quote Originally Posted by amphibious drew View Post
    Thanks for the recommendation Drew. We have been in contact, but I have been a bit slow to reply. Just started the new job and working ~100 hours a week... tis the season. Hopefully we can get everything nailed down and I will have parts headed to fastEd on Saturday.... I know what it's like to have a machine down and be waiting on that one little part!
    photo attachment is what I have for you Ed
