Homemade 6x6 with 3 cylinder motor
Page 1 of 13 1 2 3 11 ... LastLast
Results 1 to 10 of 121
Thread: Homemade 6x6 with 3 cylinder motor
    Jan 2013
    Austrailia vic
    86
    hi guys i thought i would have a go at making an amphibious 6x6 using a car motor and 6 wheels off a 4wheeldrive
    Last edited by Mike; 01-25-2013 at 04:00 PM. Reason: moved thread from Argo forum to Other AATV forums
    Cayley, Alberta
    472
    Kevin,
    Sounds like fun, you should do a search for "3 cylinder " or "home made " on this forum and see what pops up. There are a couple projects like that on here.
    Jan 2013
    Austrailia vic
    86
    yer should be i started on the frame today i will upload some pics soon
    Jan 2013
    Austrailia vic
    86
    Here are some pics of todays work
    Nov 2010
    Adair, Iowa, USA
    471
    Good start...I'm excited to see what you end up with !
    Please keep us posted with the progress :-)
    Tim
    You're not wasting any time on this project! So far so good.
    It's a great start. I think I'd make it a straight track machine and build in some floats in the center of the tracks to help with stability. Good luck on the build.
    Dec 2011
    Ontario Canada
    672
    That engine looks heavy!
    Weight distribution will be important when you float it.
    I would mount it ahead of the rear axle for sure.
    Aug 2012
    Mississippi
    126
    Are you using the transmission/transaxle that's on the engine now? If so, looks like you could shift it towards the middle and power the center axle and chain to the outter axles thus evening out the weight distribution.
    Thomas
    94 MAX IV, 16 Vanguard, Aqua Torques, 1 1/4" wheel spacers
    Jan 2013
    Austrailia vic
    86
    hi guys were the motor is sitting is going to be the front and i will be sitting back from the middle the reason i want the motor at the front is for climbing hills but i guess if it was in the middle it would be even as far as desending hills and floating.
    The motor is a front wheel drive daihatsu charade.
