True all wheel drive?
Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 65
Thread: True all wheel drive?
    Port Elgin/ Ontario
    26
    Was out yesterday with the grandkids and the wife found a deep snow drift and low and behold got stuck up on it (took tracks off -stupid move) - what I saw was that the right wheels where spinning but the left side where not - until she put the right brake on - then the left started to spin - when she let off the right brake - left side stopped spinning again - I was under the assumption that all wheels are to turn when brakes are off. ->> Question - is this normal for these machines or do I have a problem?
    Last edited by Mike; 03-11-2013 at 07:19 PM. Reason: moved thread from tire / track forum to Argo forum (assuming you have an Argo)
    Dec 2011
    Ontario Canada
    672
    I think thats normal for an Argo trans.
    Nov 2010
    Dubois Pa
    121
    The argo trans. is like an open diff axle. you have to feather (apply) the left or right brakes to get power what side that has the traction in very low traction situations like snow drifts or very deep mud holes. unlike the trans(t20) in a max, that is true all wheel drive.
    Oct 2010
    NW Ohio
    223
    It's working right. In order to get your Argo to ack like all wheel drive like T20 you will need to be fast with the right and left sticks.
    The T-20 gives you true all wheel drive, and like it was said, the Argo transmission is a differential, so only only one set of wheels will spin at a time. This is also why the engine struggles under slow speed turning with an Argo.......the differential robs a good bit of power. If you jerk the left and right sticks back and forth real fast on an Argo at high RPMs it'll generate a lot of shock load on the drive line.
    Nov 2009
    2,910
    Take a look at the videos in this thread, it may help you understand. Two camera angles, same Argo w/ wheel spin. http://www.6x6world.com/forums/trans...vs-t-20-a.html
    The good news is, with some practice you CAN learn to feather the brakes just right....and keep up with the t-20 based machines.
    Texas
    2,161
    Good point Jim, a little time behind the sticks will get an average person enough skill to keep up with a t20, not to mention having a high and low range.
    Dec 2011
    Ontario Canada
    672
    My Bazoo is true 6 wheel drive also.
    When i get high centered all 6 are spinning.
    Wish I could put a taller tire on to gain some ground clearance.
    Port Elgin/ Ontario
    26
    Thanks for the videos and I really appreciate the comments - Practice makes perfect- Lets all just have fun with what we have LOL
    Aug 2011
    Kotzebue, Alaska
    1,209
    Is the Admiral trans any better?
