Briggs Vanguard 14/16HP & 18/20HP Engine Upgrades and Identification
Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 66
Thread: Briggs Vanguard 14/16HP & 18/20HP Engine Upgrades and Identification
  1. #21
    Pittsburgh PA
    1,153
    Also need to mention that a timing advance key is worth some more power. Jersey Bigfoot claims to help a lot. I have not done mine yet, but its on the list of things to try for cheap power.
  2. #22
    Sep 2013
    Waldo Wi
    941
    I like to use these adapters from Al with those intakes, lets you bolt on a lot of different carbs if one would decide to run more compression, cams etc.
  3. #23
    Your offer is valid? you can send in Russia?
  4. #24
    Sep 2013
    Waldo Wi
    941
    Just thought I would show the difference between heads, cheap way to add compression/hp to the 16, 18 and 20's. the left is the 12/14hp the middle is the 16 and right is the 18/20. you can see the difference in the chambers which will add compression, all fit each other and use the same valves, port size N valvetrain. the steel heads gaskets help also. these heads can also be installed on the 23hp but you need to switch to the 20hp intake and change the exhaust flanges and add the hi torque starter. carb jetting and or replacement will need to be made and is better suited for the guys that don't run the governor.
  5. #25
    Sep 2013
    Waldo Wi
    941
    Graphite
    steel
  6. #26
    Sep 2009
    In Michigan out annoying the neighbors in something that has a motor in it!
    484
    Great post Nubs, thanks for the clear concise info.
    The pictures make the info very clear.
    The trouble with retirement is.... I never get a day off !!!!
  7. #27
    Sep 2013
    Waldo Wi
    941
    Thanks plumcrazy.
    just a few notes that i use if i don't have any numbers to work with, should cover 99% of what ya need.
    this link will let ya plug in your model # and the whole parts break down is all there.
    Lawn Mower Parts, Small Engine Parts & Much More! | PartsTree.com - Briggs, MTD, Toro, Cub Cadet, Husqvarna, Troy-bilt...
    just click on the briggs logo
    14HP 480cc 2.70 bore 2.60 stroke
    294447-0445-01
    Heads
    #1 / 809200
    #2 / 809201
    Head gaskets
    806085s graphoil
    807986 Steel
    gasket set
    808704
    16HP 479cc 2.68 bore 2.60 stroke
    305447-3075-g1
    heads
    #1 / 809200 (some times)
    #2 / 845716
    head gaskets
    806085s graphoil
    807986 Steel
    gasket set
    808704
    18HP/20HP 570cc 2.97 bore 2.76 stroke
    356447-0213-b1 except the two barrel intake/carb
    heads
    #1 / 809185
    #2 / 809186
    head gaskets
    690888 graphoil
    805653S steel
    gasket set
    841188
    23HP 627cc 2.97 bore 2.76 stroke
    386447-0079-g1
    heads
    #1 / 845713
    #2 / 845714
    head gaskets
    842622
    gasket set
    842658
    Please always double check the #'s as this is just my guide
  8. #28
    Jul 2011
    Garner, NC
    865
    Nubs your are sooooooo correct!! You are the Man!!!
    BIGFOOT ALUMNI
  9. #29
    Sep 2013
    Waldo Wi
    941
    Looks like Al shortened up the two barrel adapter N turned the flange horizontal, the top of that 36mm is only 3.5" above the rocker covers.
  10. #30
    Sep 2013
    Waldo Wi
    941
    Not sure this belongs here. this is what happens when a guy lets a welding BB er' 2 pop into the intake of a race motor. Sure glad It wasn't me
