Briggs Vanguard 14/16HP & 18/20HP Engine Upgrades and Identification
Page 6 of 7 FirstFirst ... 4 5 6 7 LastLast
Results 51 to 60 of 66
Thread: Briggs Vanguard 14/16HP & 18/20HP Engine Upgrades and Identification
  1. #51
    Sep 2013
    Waldo Wi
    941
    Quote Originally Posted by wjs0311 View Post
    I assume the answer is yes but we all know what happens when you assume... Will 14 hp heads fit on a 18 and will they give better compression than stock?
    Yes and Yes
  2. #52
    Sep 2013
    Waldo Wi
    941
    Briggs 805653S steel head gasket is about 0.20 thinner than the copper
  3. #53
    Mar 2015
    Quad Cities
    54
    Thanks, I'll be throwing the 14 heads on the 18 and picking up a 23hp cam and rev kit. Waiting to get the go ahead from the boss on a intake/carb setup.
    Also I'm fabing up a adjustable motor mount plate for the hustler.
  4. #54
    Mar 2015
    Quad Cities
    54
    Is there a need to re-jet the carb after putting 16hp heads on a 18hp? Engine won't run unless it is choked. I soaked the carb overnight and blew it out and it still doesn't want to run without the choke.
  5. #55
    Sep 2013
    Waldo Wi
    941
    Same jet, them carbs can be tricky to clean. gotta run small wire in the holes, had a few that never cleaned up right and swapped out a different one and it was fine
    no vacuum leaks?
  6. #56
    Mar 2015
    Quad Cities
    54
    Quote Originally Posted by Nubs View Post
    no vacuum leaks?
    I'll check for a leak tonight and if no leak then I'll take it off and run it through the sonic cleaner at work. It worked fine on the other engine but it had been sitting for a few weeks.
    Maybe I'll tell my wife that I NEED a new carb so I can get the double barrel!
  7. #57
    Hi would the carb# to convert a vanguard 14 hp to a 16 hp be # 845906 ?
    Thank you in advance for the help
  8. #58
    Can anyone provide a part number of those small chamber cylinder heads? I've been watching eBay for awhile now and never see those. If it wasn't for the picture, I wouldn't believe they existed. Thanks.
  9. #59
    Nubs,
    Is this what derates the 16hp down to a 14hp, can the restrictor be removed without issues? I've pulled the exhaust restrictors. 303447-0326/9?
    http://www.ebay.com/itm/Briggs-Strat...3D131229912003
  10. #60
    Sep 2013
    Waldo Wi
    941
    Yes, i like to just open them up and not remove them otherwise the linkage can operate funny sometimes.
    I think the head on the left is what he's talkin' about, Briggs only made them for few yrs as far as i know and are hard to find. they use the old style rockers also, the head in the middle is common for the 14/16 both old and new new rocker mounting
