All-UHMW, All-Escargo Steel, and Escargo Steel/UHMW hybrid track test
Page 1 of 9 1 2 3 ... LastLast
Results 1 to 10 of 86
Thread: All-UHMW, All-Escargo Steel, and Escargo Steel/UHMW hybrid track test
    Oct 2010
    Wasilla, AK
    923
    All UHMW vs All Steel Escargo track - YouTube shows the unbelievable traction of an all-steel track vs. all-UHMW
    One all UHMW track, One 33% Escargo steel Hybrid/UHMW track - YouTube shows how adding steel cleats helps a non-admiral Avenger 700 climb where the all-UHMW would not...at least until the trees got in the way.
    Mar 2010
    innisfil,ontario
    1,430
    nice! the steel grousers are way better.to bad they are so expensive.
    Aug 2011
    Delta Junction, Alaska
    304
    Thanks for sharing your results Buzz. I knew the all UHMW tracks would slide just like that. I need to call you and talk about steel crossers.
    Black Country, England
    715
    Why are steel grousers so expensive when the actual grouser will be cheaper? 18" x 1" x 6" of uhmw is quite expensive, 18" of 3mm pressed channel is dirt cheap ?????
    It's got me beat ??
    Oct 2010
    Wasilla, AK
    923
    It's labor. They can't be cut on a machine (UHMW) or a chop-saw then pressed like a u-channel-only crosser. Escargo's steel crosser provides excellent traction (large deep single cleat) and much more surface area in the body to "grab" when you do sink. It's a 2-piece design that has to be welded by hand. Strength is built into the design. The large single cleat on edge provides more strength than shorter channel, as well as all of the vehicle's weight on one tall cleat, not two. Floor joist are put on edge instead of flat for a reason. A piece of pressed u-channel would work much better than plastic in this scenario but has very little "body" for other situations. Plastic is more economical to cut but is lighter. My next track I think will be 50% steel, 50% UHMW and shouldn't weight much over 100 lbs per side. In the water it's buoyancy payload on the machine will be half of that. But...it shouldn't have problems going most anywhere. Not to mention, you can always wrap a steel crosser if you have problems with your winch.
    Nov 2010
    Adair, Iowa, USA
    471
    Hi Buzz...Just watched your two videos...pretty interesting comparison...good example of how the classic style tracks give up a lot of traction over the same material used in a more modern UHMW track design...im confident that the more you test the more you will learn about the ups and downs of all of these designs...lol...the classic style tracks allow a lot of track lug fold over which causes the thick grouser to lean and slip when under a "bite"...one of the reasons that a quality backer plate is necessary with this design to help reduce the "floppy" lug design of this track.....I think that on the flip side of this, the more you test, the more you will experiance all of the unavoidable drawbacks to a sharp steel cleat and you will actually see some of the performance benifits simply from the differance in material...in my opinion until somone develops a "smart" track design that can literally change its shape basied on conditions, all good track designs will excel at some specific tests, but will be a compromise in one way or another...I dont necessarly agree that a heavy steel track with a thin, sharp cleat is a great design for an amphib machine that will have to run in mud and water, but like the new "channel" track design, any steel cleat is a pretty effective track on frozen hill sides and on hard ice when compaired to a rubber or plastic track with no ice cleat... anxious to watch more of your videos!
    tim
    Oct 2010
    Wasilla, AK
    923
    I am very interested in the use of plastic in regards to weight savings and neutral bouyancy. I think incorporating its use is definitely beneficial. I do know that a 50% UHMW track is as light as I'll ever need to go. I mean, that's crazy light and skid turns awesome. Not having traction is a deal-breaker for me though. You know, I've never had problems with fold-over because the vehicle presses the cleat straight into the ground (steel). Having some fold-over on a 1" wide UHMW grouser may have allowed a sharper "corner edge" of the grouser to bite, but it was not to be. Instead the flat-cowboy bottom boot did not stand a chance. I can think plenty of places the plastic has enough bite to run with no problem, but many places a plastic grouser (even a narrower 1" crosser that should bite better than 1.5") does not work. I'm sure add-on cleats or traction enhancers would help. I like the material, but right now I'm not sure I want my entire track to be made of it. I could barely walk up the hill (I even fell and slid part way back down multiple times, and I like to think I'm pretty steady on my feet) but the escargo cleat did it's job. I really wish I could have gotten "all" the footage, but the dam* camera was off. I wasn't brave enough to try it again after I made it and the machine didn't fall off the hillside. I was "crushed" when we didn't get it on video Appreciate the discussion.
    715
    Could you not put a groove down the centre line of the grouser and insert steel "blades" with two pinch bolts through the grouser when required. Best of both worlds maybe, some bite but little weight?
    There's no charge for this ingenious idea but I would expect royalties
    Nov 2010
    Adair, Iowa, USA
    471
    i gotta admit...i love watching these videos, but some of them do kinda scare me...i was wondering what you were going to do if she got away from you..lol...i wasnt quite sure if all the trees were going to help slow down your roll, or just make for a very bumpy ride to the bottom...lol...either way, i couldnt bare to watch it twice...good video Buzz! :-)
    tim
    Nov 2010
    Adair, Iowa, USA
    471
    Quote Originally Posted by rodp View Post
    great idea rodp...that would work really well especially with a thicker 1.5" grouser and would also allow you to occasionally replace the steel blade after it had been run down a hard surface road for a ways...similar to the thick metal ice cleats used on an argo factory track that get worn down and replaced every so often...this would also allow you to substitute the metal blade for a soft rubber blade if you wanted a quieter and stickier track on rock or paved surfaces...great idea and just for the record you get the credit ...lol :-)
    tim
