Originally Posted by
MAX IV Mark
I think it is because the tracks need to be tight to stay on. As the wheels travel up and down the centerline distance between axles changes so you couldn't keep a constant track tension. So every bump would send the tracks through a too tight then too loose cycle. I have pondered how to make it work before. They work on a tank because they are sprocket driven and I think they have a idler wheel to take up the slack (George would know the answer to that).
I would think to use a track on a springer, you would have to lock each sides suspensions together making it act as if it was a right and left suspension only rather than 6 independent suspensions.
