2 stroke to 4 stroke clutch question
Results 1 to 3 of 3
Thread: 2 stroke to 4 stroke clutch question
    Jun 2011
    Rhode Island
    23
    Hi guys I'm putting a 13 hp 4 stroke in my MaxII, it had a 2 stoke. My question is what type of drive clutch should i get and or model. Do I have to change anything in my driven clutch.
    Last edited by Mike; 08-17-2013 at 11:53 AM. Reason: moved thread from Max forum to Transmission forum
    hi
    You will need a comet 780 drive series with 1400-1600 rpm enguagement
    The secondary eg a 780 series with a 28 degree ramp and either a green or red spring
    The sprocket ratios may need changing
    Contact Recreatives for recommendation on sprocket ratio
    U may purchase the primary and secondary clutch from them also
    nb all this will work on a 1 inch straight shaft for the engine
    the t20 is a 7/8 shaft
    tomo
    Jun 2011
    Rhode Island
    23
    Thank you for the info.
