Argo leans to one side
Results 1 to 10 of 15
Thread: Argo leans to one side
    Nov 2013
    AB, Canada
    14
    Question Argo leans to one side
    Hey guys, just serviced up the argo had tracks and tires off and everything, put the tracks back on and went for a burn through some snow, for some reason looking at my argo, it looks like it is leaning to one side, there is little-no distance between the track and the body on the passenger side, and a good inch or two gap on the drivers. it seems to be driving straight and isnt a rough ride. I jacked it up and stood on the tracks as they were elevated, and the gap didnt change, any ideas? IMG_5370.jpgIMG_5369.jpg I didnt see any wiggle in the axles or bearings when i had it jacked up and was watching from inside... Tire pressures same on both sides, tires measured, etc...
    Apr 2011
    598
    Just curious...Did you put the tires and tracks back in the same order and side that they were on before?
    —Will Rogers
    Look at your lower tub, does it sag from inside wheel well to outside wheel well?
    Is it only at the rear tires? May want to re-measure the rear tires also?
    Nov 2013
    AB, Canada
    14
    It seems evenly tight along the entire passenger side. The tires were replaced in the same order and places they were in originally. IMG_5371.jpg IMG_5372.jpg
    Ontario-Prince Edward County
    997
    argos can get body sag in hot weather. especially if loaded very heavy on the sides or worse if tied down with a cargo strapm over the body from side to side. if you think your machine has that problem,it has been discussed here before and most members say either jacking up or hanging the machine by the body sides and applying lots of heat over a wide area should solve the problem. if you do this, please let us know how it worked.
    Nov 2013
    AB, Canada
    14
    i'lll give that a try and let you know how it goes, thanks
    Mar 2008
    Rockwell, N.C.
    2,627
    Pick the same points on each side and measure the body to the floor. This should tell you if one side is lower. We never apply a strap across the body for this reason. It can cause the body to sag. Temperature and time can help this occur.
    Lewis
    Nov 2013
    AB, Canada
    14
    Thumbs up Larry W
    Yup! That did the trick. I was sweating bullets thinking that i had to replace the bearings on the entire passenger side.
    This is how i fixed the problem..
    I removed the tracks from the side that was touching, I jacked up the front, lowered it onto 2x4's inbetween the tires, then lowered the jack, jacked it up in the back, did the same thing so all of the weight was on the 2x4's, on the sagging side. I also added about 300 pounds to the back of the argo to make sure it worked. I then heated up the inside, and the outside with space heaters over night. Next day I turned off the heaters and let it cool before taking out the 2x4's... Problem FIXED! I have even gap between the hull and my track again. thanks guys
    997
    Congratulations on your repair. Thanks for your report and the pictures are perfect.
    Oct 2008
    Thornton, CO
    646
    Congrats!
    Space heater. Brilliant! I have my engine out right now and want to adjust the area of the tub where the drive pulley is mounted to simplify removal/installation and didn't want to stand there with a heat gun. Thanks!
