20hp honda in a argo
Results 1 to 10 of 16
Thread: 20hp honda in a argo
    Aug 2011
    pine hill al
    8
    im trying to put a honda in my argo the motor mounts arent the same as the kohler i took out im a welder and can make it work but the real problem is the old clutch wont fit the hondabut the honda has a clutch on it will that clutch work with the clutch on the tranny or will i have to change that one out as well
    Meadville, Pa
    3,286
    Was it a 2-stroke Kohler or a 4-stroke in it originally?
    Aug 2011
    pine hill al
    8
    It was a 4 stroke it was a kohler 17hp v twine the argo is a 8i/c
    Meadville, Pa
    3,286
    What clutch is on your honda. The driven clutch should be fine. As long as your not running some dinky gocart clutch, you may be alright with what's on the honda.
    Fairbanks AK
    1,456
    Measure the distance between the faces of the clutches right at the crankshaft part of both clutches. They should be within 1/16 inch to be compatible with the driven and stock width belt I believe that older one ran a 1 3/8 inch wide belt. If the honda has a 1 inch shaft I have bored the Argo clutches that thread on and had a keyway broached in them to fit onto newer engines. Was a lot of work to save purchasing a new drive clutch.
    Aug 2011
    pine hill al
    8
    My engine is a 20hp out of a land pride trekker side by side the belt on the side by side is about a 1/4 inch narrower than the argo belt should I use the argo belt or get a belt that is the same length as the argo belt and narrow as the belt off the sided by side and swap the clutch on my argo tranny to the one off the side by side tranny
    HI
    use clutches as a matched pair
    eg both argo original clutches 4 stroke ok [must be similar in hp to the Honda for swap to be effective ]
    Using the original clutches allows original style of belt [width ] but the centre to centre distance of the shafts needs to be the same also
    Mixing/Installing another type or style of clutch will interfere with how the transmission changes,most likely a poor shifting outcome .
    Remachine original drive clutch or purchase replacement that is a match for your driven
    tomo
    Aug 2011
    pine hill al
    8
    Thank for the info I'll see if I can get a clutch for my project
    Texas
    2,161
    I agree with Tomo. Matched clutches are the way to go. Rigging or milling an exhisting clutch can work, and I have done it and made it work but the shifting wasn't perfect.
    A few years back I picked up a Max4 and it had a comet unit out of a small go cart, it was a dog and could barely mud at all, It was only after I switched clutches that the machine performed as designed.
    Aug 2011
    pine hill al
    8
    Should I use the clutches from the side by side the motor came out of the only way to get the argo clutch to work would be to try to adapet the argo clutch to the honda motors shaft
