Well I hope not. I think I will make a body band now that might stop it from cracking the body if I bump in to something next time
THEY , the ATV's driven by ME and my kids hit trees occasionally. Once you install the body band, hit the trees with the body.
When you hit them with the tires, the axles bend
Nice work
Thanks
Will h5006 headlight work in my 6x6?
They work but they use almost double the power that the 18w stock lamps used, so you may find that the charging system won't keep up with them if you use the lights a lot.
OK both of my lights are burned out I didn't know they were 18w the lights I found are 35w . do they make that light any more or would led lights be best
LED would be great, but I've never seen any this size for a reasonable price. I use 35w work lights from Tractor Supply, but they still use more power than most of the two-stroke charge coils will keep up with. If you happen to find some LED lights that will fit and they don't cost an arm and a leg, make sure you post your source. There will be people interested!
I found these led oneshttp://www.ebay.com/itm/2x-New-5-Inch-Round-Pair-Sealed-Beam-Conversion-LED-Headlights-US-SELLER/121251251206?_trksid=p2052191.m2338 for 79. but I am going to try this hid set for $60 5 3 4 inch Round Clear Round Crystal Headlights Light H4 6000K HID Kit | eBay
