1.5" thick repro UHMW crosser (elevated-belt) with 1/8" steel insert
Page 1 of 11 1 2 3 ... LastLast
Results 1 to 10 of 106
Thread: 1.5" thick repro UHMW crosser (elevated-belt) with 1/8" steel insert
    Oct 2010
    Wasilla, AK
    923
    Here's a few preliminary pics of another batch of crossers from the same batch as Spookum's. All inserts are cut, now it's drill press time. These will be used on centaur-style dual-track for the Ox.
    I've got some cross-linked crazy tough UV stable UHMW en-route for some similar crossers.
    These repro crossers in 1.5" get the first go!
    Oct 2010
    Wasilla, AK
    923
    couple more. The tire profile has a very tight radius, very square. Fits turf tires perfectly. Had to add 1/8" additional width either side for the tires and tighten up the radius to be very square. Carlisle AT101's 24x12x12
    Dec 2011
    west coast B.C.
    312
    I think those crossers will work very well with the flatter tread on the turf tire. You will not get any track roll. And be far more stable over rough ground and snow.
    Well done.
    Cayley, Alberta
    472
    That 1.5" UHMW must have been crazy expensive.. $1600 or so for a 4X8?
    Oct 2010
    Wasilla, AK
    923
    Quote Originally Posted by Beeman View Post
    No....more like $1250 landed in Alaska. Places in the lower 48- along the trucking routes wouldn't have to pay as much freight as us.
    Started fastening the inserts today. The crossers are incredibly rigid when everything is sandwiched/tightened down.
    The labor for an elevated-belt track is what gets you. Once you start fabricating crossers on top of assembly ( layout, drilling rubber, washers/backer plates, bolts, put crossers on, hand-tight fasteners, flip track, final tighten, trim/bevel belting etc) in addition to doing the hinge. This style track takes a long time to build even if all you're doing is bolting on crossers. Fabricating like Escargo does or doing steel inserts is definitely a labor of love...or something
    May 2011
    North Pole AK
    768
    Yah... With the extra labor involved I hope the steel inserts will be with it! How much steel do you have sticking out?
    ATV = Alaska Terain Vehicle
    Oct 2010
    Wasilla, AK
    923
    Quote Originally Posted by spookum View Post
    3/8"
    I used 1 1/4" flat bar, .125 thick. UHMW height under tire is 7/8 for a total of 1.25" cleat height including steel. Next time I'll use a smaller routered edge and maybe another 1/8" UHMW...maybe. Once the 1/4" bolts x 3 (grade-8 overkill) are tight, that thing is a real stiffy. So I don't think a guy "has" to go taller on the UHMW, especially if a stronger more abrasion resistant grade is used? We'll see. The steel insert I think will really protect the UHMW from hardpack that might "mushroom" reprocessed UHMW over time.
    Oct 2010
    Wasilla, AK
    923
    What I've found with the UHMW so far (up here) is that it goes from looking "brand new" to basically getting scuffed up / gouged up more or less immediately. Then it stays like that for a long time. You'll slowly scrape small pieces away from any mushroomed edges, but it takes a long time. The process kind of repeats itself over the "wear-life" of the cleat. Cleat height/thickness comes into play too. A better grade of UHMW would hold up a lot better, but extra thickness if using reprocessed helps.
    Mar 2012
    Brooklyn, WI
    885
    I've found the "mushrooming" as you refer to it sort of aids in traction. My Max IV has about 150 hours on it's tracks and I really can't detect much wear even with a caliper.
    Keith.
    Oct 2010
    Wasilla, AK
    923
    Had a little garage time today. I think I knocked out about 50 crossers. Haven't tightened the inserts yet, but it's starting to look like something-
