I have a hustler with the k440-2ax in it. I read that you are supposed to set the timing with a depth tool. I'm talking about adjusting the timing plate by finding tdc and checking the points opening. I kinda understand what to do and I have the tools. But the problem is I can't see my points with my flywheel on or adjust anything. If I take it off to adjust the plate then I can't turn my flywheel to get everything lined up. I'm stuck. Does this really need to be done or can I just line up my timing mark on the plate and the block. image.jpgimage.jpg
