Conquest mud flaps
Results 1 to 4 of 4
Thread: Conquest mud flaps
    Conquest mud flaps
    Does anyone know if the Mud flap kit 625-10 will fit on a Conquest?
    if not, what are Conquest owners using?
    Does the kit come as a pair? or do you have to order two of them
    Believe so, though didn't check the option number. The rear contour at the seam of the Argo is pretty much unchanged since the 70's, if you find an issue they are easily trimmed and could also be trimmed to fit the front.
    Come as a pair.
    Nov 2010
    Adair, Iowa, USA
    471
    The radius on the rear of a machine was changed starting in 2004 with the new body style of the Avenger. The new bodies have a tighter radius than the older Conquest (and bigfoot, and response, etc). Adair Argo has been machining them from 3/16" UHMW so that they are unbreakable as they sometimes seem to get bounced up against trees :-) you can actually get them in three different widths depending on your application and there are flaps made especially for the front corners as well. Hope this helps you.
    tim
    Awesome
    I will give adair a shout
Tags for this Thread
